Guest ericf
it should be good to extend the event display window.
It should be good:
- to be bale to change the log level (DEBUG, ERROR, WARNING, INFO, ...) when the HC2 is up and running and working only some info are required --> better for performance
- to have the search feature, to find more easely some information like to limit on an object, type of message, object ID, to limit on a part of a room, ...
Like you could do on Linux the analyze the /var/log (find command, ...)
Eric
