Icons list ... (to be able to choose ...)
Guest ericf
a lot of nice icons are available on the box ... a lot but depending the component you try to create (like a room) the possible icons are limited.
It should be possible to have a search/file explorer that will allow us to select between the folder on the HC that contains all the icons (sort already by type and sub-directories)
Guest ericf
    But the graphics/layout/icons are GREAT ...
    nice job
    yeah. i agree. Very nice graphics, good job!
    What icons i need:
    garden icons: front and back garden
    cellar icon
    attic icon
    pond icon with fish in it
    thanks,
    maybe there are more requests?
    Guest ericf
    a lot of icons already exist on the HC2. ( a lot are in the file system of the HC2). they are also group by type.
    They (Fibaro) have only to allow you/us to browse it and be able to select one.
    Guest vayher
    You can upload your own icons to the system (for rooms and devices). When you're in "change icon" section, there is a field for upload. If you like for example some our device icon and you would like to use it for rooms, just save this icon from the browser ant then upload it to the HC2 in the room icon change section
    Guest ericf
    ok for the tip, but we should be allow to browse all icons in the HC2 file system
