FEEDBACK on 1.019
Guest ericf
First steps on 1.019
- nice graphics/icons/...
Feedback:
- should be able to list and select between all available icons
- should be able open/close part of the house/rooms. If you click on element of the house it doesn't open/close the component --> they are all listed so which multiple components on the screen it becomes to long ..; and you have the scroll the window. it works on Devices tab when you click on an room (show or hide list of component linked to the room)
- on my module AEON LABS Door/Windows sensor, and set it to disarm, it still send notification. should it not be ignored are have a 3rd state --> Ignore ?
- still think that we should be able to select the type of module (the factory that has develop the product and the model), so related to this info a specific window/parameters should be available on the user has only to set default and advance parameters without have the required knowledge of all parameters of the component.
but ... ok great job ...
Guest GrZeCh
    to anyone interested I've attached small self made application which will allow you to test how virtual device works (tcp listener):
    (added as attachment to one of my posts).
    Regards
