Supported Z-wave + Best practice
Guest ericf
we should fill-in a list of supported module tested by end-user that have a HC2. Also the share of the problems, knowledge, solution, parameters settings, recommendation should be shared.
Guest ericf
    - Actually fully recognized
    - Master has the good icon (nice )
    - the sub-element also:
    - temperature
    - luminosity
    - motion
    For settings parameters, you have to add your-self the parameters in the advance tab and add parameter by giving the good parameter ID and value. Then res-sync with the module by clicking on the blue button on the EZMotion --> you will see the led of Z-wave on the HC2 flashed.
    Actually i have set some of them, like deactivate the LED so preserve a little the battery:
    parameter ID : 3, value : 0
    Eric
    Guest ericf
    Also to change the sensibility:
    - set parameter ID: 1, Value: 10 --> Pet Immune
    Recommended values:
    10 = Pet Immune
    100 = Medium sensitivity for hallways
    200 = Highly sensitive for rooms where people are sitting still
    Guest ericf
    - fully supported
    - nice icon of a door (open/closed depending the status of the module)
