Hi to all!
What do you all think as we make a topic for scene programming?
It could be very cool to post some interessting pics of scenes you programmed.
Beside the pics you can tell why you made the scene and youre idea with it.
I think it will be inspiring for us all and help to programm the scenes we need.
Let me hear what you think about this idea?
regards,
Emiel Theunissen
Smartronix
Guest ericf
yep good idea.
A topic for scene should be create with the following header:
ROLE: role of the scene
ELEMENT : elements controlled
    Ok , i'll be the first.
    Lets begin with a very simple scene.
    - One light in the living room should be on at sunset.
    This is a nice scene , you never come home in a dark livingroom, and it's just like there is someone at home even when youre on holiday.
    In another scene i turn all the lights and some appliances off at 00:30 ( time i usual sleep)
    So there never burns any light whole night long, because i forgot it. Even my sunshaders are closing at that time.
    Hope someone will follow me with some good scene ideas!
    I have a dimmer and a motion sensor in my Hallway and I would like to set a scene to do the following:
    -Between Sunrise and Sunset, when motion is detected lights turn on to 100%
    -I then want the lights to gradually dim to off (over the space of 40 seconds)
    I can build a scene for them to come on to certain brightness and turn off after a certain period, but....
    I have to select a time period as the Sunrise/Sunset parameters only allow for "At sunset" or "At sunrise". There is no option for "between" or "*time period* before/after"
    Can someone show me how to slowly dim the lights in the scene settings over a period of time? I don't mind if it is done in 3-4 "steps" or "push dims" but a smooth transition would obviously be nice
