jasontodhunter 0
I have the unit successfully operating and triggering a fibaro relay module by means of linked devices and control panels. Good news!
1, I can set the parameters regarding Temp / Humidity thresholds using the parameters config option under advanced settings. Is the blue box supposed to show the current settings when you do this? At present I can only tell if parameters have been changed by going to the unit.
2, If I set thresholds for temperature manually on the unit can these thresholds report to the HC2 to trigger an event
7 answers to this question
