EzMotion Light Value based scene
derelict
Hi
I seems as if i'm unable to create a scene using the reported light level of a EZMotion 3 in 1 in a scene in order to turn a light on, only if the light level is lower then the set level.
It's also a little bit confusing, that the "light level" device of the 3in1 is handled like the motion detection device in the scene (breached, safe, on,. off).
how to i build a scene like:
IF "ezmotion light level" is LOWER THAN 7% THEN turn "light" ON ??
4 answers to this question
  • btw: i know that i can set a similar feature on the device itself.... but that's not practicable in my case.
    Guest hotrot_net
    I tried these setting today with version 1.024 they are working..!!
    Guest hotrot_net
    Oeps that does not work, i tryied to change te value it reacts on any value you fill in
