enhancement required about delay of executing scenes
I'm owner of a Vera2 system and the new and shining Fibaro HC2.
even if HC2 is a new product, he encloses a great potential. The graphics is amazing!
Very great step forward in home automation.
I know it's young product, but right now, the biggest problems are the response times when listening the devices change status into scenes.
let's me explain better:
assume this scene:
IF MOTION SENSOR IS BREACHED
THEN TURN ON LIGHT
the problem is when the motion sensor is reached, HC2 spend near 4/5 seconds before turn on the light.
With the same setup, vera2 make the same operation in near 1/2 second.
So I think HC2 can be tuned better to response more fastly to zwave events.
I expected this by default because from
I read:
"Large memory + fast processor = quick communication between Fibaro System devices. Hardware architecture used in Home Center 2 makes Z-Wave based home automation system work much faster then ever."
another question:
I want access the HC2 box via ssh, what is the root password?
Best Regards
I agree! I am the owner of the same systems, and one of the main reasons I switched to HC2 was the strong hardware. I expected better response time than the vera, instead I experience it slower.
Guest kstaniek
Jin, if you want some hints how to root your HC2 just let me know on pw or email.
Guest vayher
We are working on new engine of executing the scenes. For now I can't tell what's the deadline, but it will be a huge change. Scenes will work / devices will respond many times faster than they do now.
