Aplikacja na iphona HC2 - status
Guest Fidziu
Z przykroscia donosze iz ponownie apple doczepilo sie do naszej apki tym razem o gps.
W tym watku bedziemy informowac o progresie w tej kwestii.
Ponizej info od appstre:
We found that your app uses a background mode but does not include functionality that requires that mode to run persistently. This behavior is not in compliance with the App Store Review Guidelines.
We noticed your app declares support for location in the UIBackgroundModes key in your Info.plist but does not include features that require persistent location.
It would be appropriate to add features that require location updates while the app is in the background or remove the "location" setting from the UIBackgroundModes key.
If you choose to add features that use the Location Background Mode, please include the following battery use disclaimer in your Application Description:
"Continued use of GPS running in the background can dramatically decrease battery life."
For information on background modes, please refer to the section "Executing Code in the Background" in the iOS Reference Library.
We began the review of your app but are not able to continue because we need access to a video that demonstrates your app in use.
Also, please clarify the use of location background mode. Does the app need to use location persistently in the background? Thank you.
You can provide a link to a demo video of your app in iTunes Connect. Go to "Manage Your Applications," select your app, click "Edit Information," then scroll to the "Review Notes" section and add the demonstration video access details.
Dostali juz to co chcieli. Rewizja teraz powinna potrwac max 2dni. Ale niestety trzeba poczekac.
