jin 0
I figured out that after some hours fibaro gateway become unresponsive.
searching the cause of the problem I discovered this:
top - 21:29:16 up 1 day, 12:53, 1 user, load average: 4.01, 2.35, 1.81
Tasks: 113 total, 5 running, 105 sleeping, 0 stopped, 3 zombie
Cpu(s): 87.8%us, 12.2%sy, 0.0%ni, 0.0%id, 0.0%wa, 0.0%hi, 0.0%si, 0.0%st
Mem: 1023800k total, 367572k used, 656228k free, 45724k buffers
Swap: 249848k total, 0k used, 249848k free, 99812k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
3466 www-data 20 0 42272 15m 5568 R 51 1.5 1:13.81 php
4086 www-data 20 0 42272 15m 5568 R 51 1.5 0:10.53 php
2974 www-data 20 0 42272 15m 5568 R 46 1.5 2:13.18 php
2236 www-data 20 0 44016 13m 3192 R 28 1.3 4:26.47 apache2
1232 mysql 20 0 139m 21m 6100 S 5 2.1 12:24.73 mysqld
13908 www-data 20 0 44532 13m 3192 S 5 1.4 4:21.11 apache2
root@fghc2:~# ps aux | grep php
www-data 2974 76.5 1.5 42272 15480 ? R 21:26 2:15 php /var/www/fibaro/advanced_scenes_check3.php 49
www-data 3466 70.2 1.5 42272 15480 ? R 21:27 1:15 php /var/www/fibaro/advanced_scenes_check3.php 49
www-data 4086 45.5 1.5 42272 15476 ? R 21:28 0:12 php /var/www/fibaro/advanced_scenes_check3.php 49
root@fghc2:~# strace -p 2974
Process 2974 attached - interrupt to quit
time(NULL) = 1332620935
and so many many other lines..................
This bug is caused by a scene like the attached screenshot.
Moreover the problem is accentuated by overlap of the triggered scene (each time the motion sensor become "safe" the scene timer start). In a future release would be great if I can enable a check into scene programming to make certain scenes to "run only once at a time".
Let's me know if do you want major details.
Thank you very much for the support.
Best Regards.
PS. please put online a bug tracking system like Mantis BT to manage the bug reporting of Fibaro System, so these bug reports doesn't get lost into forum posts.
5 answers to this question
