[HC2 - 1.021] List of devices with predefinied parameters
Guest kstaniek
Based on the information from HC2 internal DB here is the list of supported devices in software version 1.021:
FGD211 V1.4 DIMMER
FGD211 V1.3 DIMMER
FGD211 V1.2 DIMMER
FGD211 V1.1 DIMMER
FGR221 V1.0 Roller Shutter
FGR221 V1.4 Roller Shutter
FGR221 V1.1 Roller Shutter
FGR221 V1.3 Roller Shutter
FGR221 V1.2 Roller Shutter
FGS211 V1.3 Switch ON OFF 3kW
FGS211 V1.4 Switch ON OFF 3kW
FGS211 V1.2 Switch ON OFF 3kW
FGS211 V1.0 Switch ON OFF 3kW
FGS211 V1.1 Switch ON OFF 3kW
FGS221 V1.4 Switch ON OFF 2x1,5kW
FGS221 V1.2 Switch ON OFF 2x1,5kW
FGS221 V1.3 Switch ON OFF 2x1,5kW
FGS221 V1.1 Switch ON OFF 2x1,5kW
FGS221 V1.0 Switch ON OFF 2x1,5kW
ST814 Temperature / Humidity Detector Everspring
ST815 Illumination Detector Everspring
ST812 Flood Detector Everspring
SP103 PIR Detector Everspring
SM103 Door/Window Detector Everspring
AN157 ON/Off Plug Everspring
SE812 Indoor Siren Everspring
FGD211 V1.0 DIMMER
FGR221 V1.0s Roller Shutter
SF812-1 Smoke Sensor Everspring
Aeon Labs Door/Window Sensor
Danfoss Living Connect Thermostat
Horstmann HRT4-ZW
Horstmann HRT4 ASR-ZW
EZMotion 3 in 1
Hortsmann AS2-RF
FGD211 V1.5 DIMMER
FGR221 V1.5 Roller Shutter
FGS211 V1.5 Switch ON OFF 3kW
FGS221 V1.5 Switch ON OFF 2x1,5kW
6 answers to this question
Guest kstaniek
    WARNING - This is the DB snapshot only! There is no guarantee that all devices from above list works with HC2 until confirmed by Fibaro.
    Guest ericf
    small list
    Guest gembrain
    Bit of a disappointing list.
    I read in another post that they've got 150 products on site ready to test for compatibility. Hopefully they will be working on those as a priority.
    Get all the basics right before working too much on the more fancy stuff....
    Guest Fidziu
    kstaniek [/ b],
    I asked you already do not mislead users! You'r publishing some of your over-interpretation and preach heresy!
    THIS IS NOT A list of supported devices!
    This entries in that tabele are prompt for some advanced features in some devices selected by us that user does not have to configure them through the parameters and are also used for some other purposes and has nothing to do with the supported devices list!
    The list of supported devices is much greater!
    For example: switch duwi, Merten, Aeon, everspirng, and hundreds of similar devices are operated by HC2. Operation is dependent on the class that uses the device, thats all!
    You are not able to check it because they are compiled in the HC2 zwave engine.
    From the HC2 O.S. perspective aeonlabs or any third-party motion sensor is the same device.
    So the last time please, do not publish more of such posts because you do not have sufficient knowledge about that subject!
    Guest kstaniek
    Thanks for replying.
    As I wrote this is the snapshot from internal DB.
    That's perfect!
    Could you provide the official list of supported or unsupported devices, thus?
    We would like to know what is supported prior buying new devices.
    When you read the threads you will see that there are more and more questions coming up about asking for support of specific modules. Should we ask Fibaro every time when we want to buy new device? That's crazy!
    This entries in that table are prompt for some advanced features in some devices selected by us that user does not have to configure them through the parameters and are also used for some other purposes and has nothing to do with the supported devices list!
    Thanks for clarifying. That would be very nice to have a piece of documentation saying about this.
    Sure I don't have. The only authoritative source of information is Fibaro. I think it's clear.
    Hi
    I see in the list below, even if this list isn't official that the SM103 Door/Window Detector Everspring works fine, what 's about the new model HSM02.
    The association is OK but there is no action on HC2 when i open or close the HSM02 (except one time see in log :parameter 255 to 0).
    May i configure parameter manually and which one?
