Hello!
I have not yet transfer the z-wave devices in to the HC2, it's only in test use.
So i turn off the device in the evening, and put power back on again the next day.
Problem is that it freezes up about every other evening.
At boot, the LEDs light up one after another, until all are lit and then unit freezes.
All leds stays on. It don't even answer to ping.
After this, the device must reset with the recovery button.
Anybody else having similar problems, or I'm doing something wrong.
At least here in the promised land of power cuts, this does not seems very promising.
Mitam
6 answers to this question
Dear Sir!
Is it possible to connect, by internet browser, to configuration panel of HC2 after these restarts? I assume that You've wait sufficient time, because after restart our HC2 need some time to proper configuration (even few minutes)...
Regards
Guest ericf
I had the same ... I have done a recovery but it didn't solve it.
I have return the box and receive a new one.
Eric
    When it freezes in restart, i can not connect to it by browser.
    I waited sometimes even hours,but no change. All leds just stays on, and it wont even answer to ping.
    Then i have to do recovery, after that all is fine. This happened many times.
    But for some reason, this problem has not been just over a week now.
    Just like the recent firmware upgrade would helped?
    Just have to wait and see, if the problem is over.
    Mitam
    Guest Fidziu
    Mitam,
    What is your HC2 serial number?
    My HC2serial is HC2-000256
    I had also some freezes yesterday when adding virtual devices.
    when there is no GET command in front of the string to sned HC2 will freeze.
    Firmware 1.024
