Pascal 0
I connect two foscam camera on the HC2 but if i try to look on the lan there is no problem to see the video, but if i try to see without my lan there is no video.
i add the camera with the intern IP 192.168.1.111 i think that the HC2 stream the video directly from the Camera and work not with a video cach ... is it possible to do this ?
I configure a dimmer to set the ON to 0,2 seconds only to give a impuls to open a door and he switch direclty to OFF after 0,2 seconds but the problem is that y have no status door open or door closed .. is it possinle to when i set to ON that the dimmer after 0,2 seconds is set to OFF but that the HC2 status will still to ON and when i click on OFF that the door close ..
Is it possible ?
Thanks for your help
Kind regards
Pascal
6 answers to this question
