Can you confirm the new update for today ?
Can you give us more information about this update ?
Kind regards
Pascal
Guest kstaniek
Yeach, it's coming:
look at this: www.updatehc2.fibaro.com/info
but needs to be confirmed and officially released by Fibaro!
  • 1 month later...
Guest yassinejaridi
hi all,
is there someone in this forum who can tell us what's new with this new update?
thanks
Software Changes List 1.025:
- New device configuration screen for security system management
- Adding French language
- Adding Dutch language
- Bug Fix in the display of logs at the device (after the expiry of the session logs will be displayed in default language)
- Bug Fix in the scenes using the illumination sensor
- Mail with a photo of the camera - multilanguage in the email subject and improved formatting (some e-mails were marked as spam)
- Mail with the notice of change of status of the device - multilanguage in the email subject and improved formatting (some e-mails were marked as spam)
- Correct display of maps in the location panel in remote access,
- Adding the "level of position" for blinds in the application for iOS
- Improved performance on the type of filtering device in the left menu in the control panel
- Improved changeod scene's icons in an application for iOS
- Improved "saving" in panel heating - after saving the user is no longer redirected to the main page
- Improved scenes based on a combination of timers and weather
- Virtual devices - adding to the buttons and sliders to the "Wait for an answer" - it reduces waiting for the response of the device and the interface does not freeze
- Improved removal of rooms icons
- Translation bugs fix
- Added parameters for the device 3in1 EZMotion
- Improved procedure for adding new parameters (in some cases, after adding a new parameter values %3F%3Fchanged back to previous)
- Issue with the crashed table resolved (Table is marked as crashed and should be repaired)
- Adding the possibility to download the beta version of the software ( after releasing new beta version of the software in Configuration Panel additional link will appear )
Guest ericf
thanks ...; seems cool will test this
Guest PC@HOME
Hopefully the problem with the Everspring motiondetectors will be resolved. Will try the update out tonight. Keeping my fingers crossed.
Sorry, but I try this morning, and the problem with everspring motion detector is the same... Not working for now..
It seems that Ezmotion 3 in 1 work better.. Is it true?
Bye
I just test with Everspring SP814 motiondetector, and it works just great.
How it's possible?? My Everspring motion detector doesn't work from 1.020 firmware!
And I try to reset, exclude, include, reset HC2, etc... but nothing..
So I think there are more version of the same product?
Bye
Everspring SP103 works fine also and have had it running since 1.019
Yes, I know, but SP814 is little better so I can put it on a wall or a ceiling, and it has 360° detection range... and it cost like the SP103 =)
I agree with Lumel.
My Everspring motion detector SP814 doesn't work even in 1.025 firmware!
I also try to include, the first time in 1.024, the dectector is created with an ID and a ID nod, but it doesn't work at all and now i can't exclude it in 1.025.
I have the same problem with another Everspring module HSM01
HSM01 wich products is from Everspring?
Sorry, it's not the HSM01 but the new Door/Window Detector Everspring HSM02.
The association is OK but there is no action on HC2 when i open or close the HSM02), no log in event panel, no mail send etc...
Are you sure? I have a HSM02 door/windows sensor and it works fine (I see icon change opening door)
I load the new version 1.026, and effectively my first HSM02 works fine now and i try with a second one, the association is good but the icon stay open and no message in Event panel except the first time.
And now, new problem, "FIBARO server doesn't answer"!!!
I restore a sauvegarde 1.024
I have re install a backup ( version 1.024.)
Strange. The Web interface indicate 1.024, however the interface is in French (contribution of 1.026) and the Led "dowmload new version" on the box flashes but no message of new version in web interface
I just test Everspring SP814 motiondetector little more.
I got it to work earlier,so just wanna test can i do it again.
Answer is no. Just can't include it any more. Strange?
Guest haka
With the latest software version the motion detector MomPro ZIR010 is not working anymore. It;s also not possible to configure the parameters, include or exclude is also not working anymore. It WAS working 1.024!!!
