How to associate Group 2 of Fibaro 2x1.5W from other Fibaro?
Guest manfaiho
I found that the association for Group 2 of Fibaro 2 x 1.5W double loads with switching ON/OFF from another Fibaro Dimmer, 1x3KW even 2 x 1.5W relay is NOT possible. I can only make the association with its root device -> Group 1 only. I can set the association for Group 2 (from Device option -> Group settings on VeraLite with the latest firmware) but still can only view the association to its root device. Is it a known problem for Fibaro 2 x 1.5W issue. If not, how do I set the SW2 on Dimmer, 1x3KW or 2x1.5W relay to switch ON/OFF another Fibaro 2x1.5KW relay's Group 2 (Second switch)?
Dear Sir!
Right now You can only associate devices in Group 1. Probably in future updates there will be additional capabilities
Regards!
Guest manfaiho
    Thanks your confirmation :->
    In the future, how do I update your existing device? Is there firmware that I can update via VeraLite MIOS? If that, it is a perfect solution. I love your solution at all.
    Dear Sir
    I had in mind, that if we will add this functionlity in future it will be only added in our Home Center 2. I can't say what will be added in future Vera updates?
    Guest manfaiho
    Disappointed if it is only for HC2. For the best arrangement, I suggest to file the bug to Vera who can plan to fix it as schedule as the workaround should only apply on Gateway instead of relay itself. Is it correct? Can you share more about the problem detail and approrpate workaround (Mainpower OFF then ON?) so that we can have this function work in a short term? Thanks.
