Unable to upgrade to v.1.024
I´m currently on version 1.021 and trying to update to 1.024.
Everything seems ok when I press Start for update but after about 30 seconds I get "upgrade error 6" and a button that says "Close". Pressing this button get the system to freeze and when I then try to connect to homecenter again by using 192.168.... i get a window that says something in polish.
Apps on iPhone and iPad are unable to find homecenter and the only way to get it to work again is to do a reboot by pulling the power cable. After that everything seems to work again and the system tells me to upgrade to 1.024 which start the same procedure.
Anybody that knows how to get around this?
/Dennis
Guest ericf
do first a recovery ... then it will be on a old release and should be able to upgrade.
Eric
