I'm trying to understand the logic of scenes.
Some questions..
How can I start a scene 15 minutes before sunset ?
This one of the most logical options to use...before it's dark outside turn on some lights.
What is the meaning of (h:mm) when I select 30 minutes after sunset? see screenshot.
How can I randomize the time ..to simulate presence at home?
5 answers to this question
Dear Sir
Hour and minutes argument only works with "An exact time" option, when You change for example for 30m after sunset the hour/minutes argument is skipped. The easiest way to randomize the time and simulate presence at home is creating multiple different scenes with multiple timers.
Regards
    REQ:
    Please remove the "Time info" when user select option that don't need the time.
    This means before sunset is not possibile in the current version?
    It will be easy that you have two options
    Before and after Sunset without time
    When user selecte one of this options user can define the time before/after. (h:m)
    Enver, youre right i noticed this also, its a bit confusing...
    When you made a scéne with sunset timing as a parameter the clock setting isn't usefull, the only thing it does is remembering the time you made that specific scene.
    In my opinion a better solution could be to have before/after sunset option without any other indication and then in the h:m you can choose the interval before or after the event above.
    Guest MitchellOnline
    Here the same, I am really missing the function to switch 15 or 30 minutes BEFORE sunset...
    This could be easily programmed in the HC2-Software.
    @Fibaro can you fix this?
