Fibaro Dimmer Type?
If you take the fitting out of the ceiling there should be a transformer between the switch and the lamp fitting. Check this is making the noise
I had this issue and had to change some (every now and then) transformers.
I use OSRAM electronic red/black transformers and they work fine. I will try to get more specifics so you can find something suitable in your part of the world.
I have not used a dimmer on a fan before. Fan controls are slightly different to lighting. How was the fan speed controlled before you put the fibaro dimmer in?
  • 10 months later...
Guest Kuuno
    does anyone have experience with osram par16 4w dimmable leds? what should the param. 20 be set to?
    thanks!
    • 1 year later...
    I can confirm that Master LED 5,5 W 827 350 lumen GU10 40° working with Parametr 20 set to 135 and three wires connection (with Neutral connected). Without bypass or such things.
    Dimmer ver.2.2
    6 bulbs load
