HC2: Deleting device error
Keep getting this message when I try to delete a device. Anybody have the same problem?
6 answers to this question
Did You try to remove device phisicly from the system (Devices -> Delete Device), or only from "Your home" tab?
I did experience the same few times yestday/today. I'm pretty new and just believed it to be 'normal'. Typically after 2 tries its ok and deletes. Yes, the proper Devices - Delete Device Tab. Its another Jeroen who told me to use this one unless the device is broken and you have no option!
Cheers,
Hans
    I tried three different ways and it works after a few tries. but still cannot give you more inormation then that. Tried via Devices, Your House.
    Unless you use the Delete Device function (HC2 goes into learning mode) the device is locked to that particular controller and can not be added to another. I expect that this a security measure. If you are a reseller of FIBARO and you are testing devices for sale you should always delete them this way or they will not be found by another HC2
    @ Johnny This is actually not true. I have a seperate remote which I directly link to light switches that I also have linked to the Fibaro system. I agree that it's best to remove devices this way.
    Sorry, I meant to another HC2
