jasontodhunter 0
I have linked an axis IP camera and fibaro relay module to release a gate using the Video gate function. The function works reliably from the browser. It also works from the iphone app but the open command becomes spurious after a number of triggers on the iphone also.
Also using the open button on either the browser or the iphone pulses the fibaro relay briefly not once (as you would expect to release the gate) but twice every time. Why does it do this and can the pulse length be adjusted?
Update an auto off timer was set on the fibaro relay module. I have disabled this and the output only triggers once now.
Response to iphone app still hit and miss after a number of triggers. There is a scene attached to the relay module to bring lights on for a number of seconds maybe the scene running slows things up!!!
