Question about full concept "Fibaro System"
Guest zebox
Hello!!!
I am interested in a possible implementation of a complete concept.
/files/fibaro_701.png" alt="fibaro_701.png" />
1. Lighting - use Fibaro modules
2. Blinds - use Fibaro modules
3. Intercom - ??? what devices can use for this section??? Support SIP ?
4. Gate - use Fibaro modules (for example, Relay Switch 3kW)
5. Climate - What thermostat devices support(compatible) HC2? Any Euro Z-Wave? Can I manage split-systems?
6. Equipment - what does it mind ?
7. Camera - Any IP-camera.
8. Multimedia - How can I integration my multimedia system for manage with HC2???
9. Alarm - Configuring sensors or other detect devices for some events?
10. Sensors - I understanding for this use sensors. What sensor devices support HC2? Any Euro Z-Wave?
11. Watering - what devices use for implementation this function? Use basic Fibaro switch modules?
Could you explain this ? Thanks!
Guest Kuuno
    Hi and good topic!
    1. Lighting - use Fibaro modules - yes very easy to install and use
    2. Blinds - use Fibaro modules -same!
    3. Intercom - ??? what devices can use for this section??? Support SIP ? - fibaro guys will add more here but as far as ia know you can us most of intercom solutions and then use fibaro to control the bell and door open actions. these are built in to relay switches. What i did is i added external IP camera as intercom camera and then you can connect bell button to relay switch to nitify you of guests
    4. Gate - use Fibaro modules (for example, Relay Switch 3kW) yes but also keep as much as possible original automation!
    5. Climate - What thermostat devices support(compatible) HC2? Any Euro Z-Wave? Can I manage split-systems? currently horstmann should be used mostly, im testing couple other things and will let you know of the results but best should be horstmann
    6. Equipment - what does it mind ?-toasters and etc but that depends a lot on the device itself. eg turn on water heater at 08.00
    7. Camera - Any IP-camera. pretty much yes, i managed to add usb camera also...
    8. Multimedia - How can I integration my multimedia system for manage with HC2??? - this is little raw currently but IR controller should be available soon then you can control pretty much everything! there is virtual device support but that is not that comfortable yet
    9. Alarm - Configuring sensors or other detect devices for some events? this is possible but for security i recommend to use a dedicated device that you can integrate with fibaro.
    10. Sensors - I understanding for this use sensors. What sensor devices support HC2? Any Euro Z-Wave? - i have tested aeonlabs, everspring and they work ok-water sensor, door window sensor, and 3-in1 motion sensor
    11. Watering - what devices use for implementation this function? Use basic Fibaro switch modules? use that + electornic water valve to open close water flow-i have similar system
    regards
    Kuuno
    Guest zebox
    Thank you for reply!
    Else some question about:
    Equipment - for this must use special equipments which manage with outlet switch?
    Climate - Can i control Split-systems, may be send control commands?
    Other things of understandable
    /emoticons/default_icon_cool.gif" alt="8-)" />
    Guest Kuuno
    currently yes, the device must be switchable on/off w outlet. therewill be an universal module which can be used to control more precisely but its currently in todo list
    what do you mean by split systems?
    Guest zebox
    Split system = conditioner:
    Guest Kuuno
    is see that it uses IR to send commands so probably this is possible in near future hopefully.
    it should not differ much from controlling audio BUT probably you can do simple things such turn on/off
    switch to heating/cooling
    increase/decrease temp but you will not get feedback as the device itself is not zwave compatible
    Guest zebox
    Yes, i know about one way control, but I would accept such a method (not get feedback).
    Could you recomend some IR transmitter with Euro Z-wave support for this
    /emoticons/default_icon_question.gif" alt=":?:" />
    Guest Kuuno
    this is currently under development and i would recommend to wait for wa while and not buy IR control device yet. as it will be announced here then add this to your system!
    Guest KubaW
    I recommend Global Cache boxes. You can send commands over LAN or WLAN using virtual devices. We use it to control our projector. I wouldn't wait for dedicated z-wave IR transmitter...
    Guest zebox
    Could you recomend vendor Intercom for integration with HC2 ??
    Guest GrZeCh
    You can consider checking Daikin new solution called OnlineController:
    (polish blog)
    It could be probably (needs checking because I'm not sure if authentication can be bypassed) controlled using VirtualDevice from HC2.
    Guest zebox
    about control conditioner: anybody used this ZXT-300 ?
    I think it is can send IR command to IR control devices
    • 1 year later...
    bump.... please provide us with the recommended list of compatible HW.
    Also, is there any dev going on for IR integration? may be a list with preconfigured virtual devices (think of remotes for some TV's or the VU+ or Dreambox... those should be easily adressable for you guys?)
    For IR integration, use Global cache iTach. Easy to learn IR commands and use them in virtual devices.
    Still should wait?
    • 3 months later...
    Guest Eduardo
    I have a Daikin split and the global cache itach felx solution, but the global cache can´t learn the IR commands and the solution doesn´t work. Tried several IR commands but still nothing!
    Any ideas??
    • 4 months later...
    I'm just going to order Daikin Online Controller and try a http integration.
    • 5 months later...
    OK, here's an update for Daikin users.
    I've started decoding the Daikin protocol used by the newer units (Remote ver ARC466A1) with some important help from Chris who works with AnalysIR and so far I have made significant progress! The process is a bit time consuming but a very fun puzzle to solve
    With a few more hours of work I should be able to generate proper codes "from scratch" which makes the home automation process a lot more dynamic. When the protocol is decoded the next step is to encode codes and get the modulation correct to make the transmissions reliable. I've had some success here but this part needs to be improved.
    great!
    Let us know if you need any help, Daikin AC issue has been there unresolved for very long time. email to [email protected] if you need any help.
