I want to control the irrigation/sprinklers in my garden based on the moisture content of the soil. Does anyone have any products that are compatible that measure the moisture level of the soil and can send a command to turn on my z-wave controlled valve when the moisture reaches a predetermined level?
We are releasing new universal binary sensor module. Thanks to it, you will be able to connect any binary sensor to home center 2.
Guest domoticawireles
When this new module will be avaible for european market?
Can you tell us some features of this module?
Dear domoticawireles,
As far as I know this module should be now available in european market.
This module will allow to connect every binary sensor to our z-wave network, and You will be able to connect to it up to 4 DS18B20 dallas temperature sensor. Also You will be able to connect it into alarm programmable center, also with parametric line.
