budda 5
I've currently got 2 danfoss living connect thermostats.
They added fine to HC2 and i've set up a weekly schedule to change the temperatures.
This works fine - and I can see the HC2 sending the change in temperatures.
Pressing the middle button on the thermostat also displays the correct temperature value that HC2 sent.
However neither of them appear to control the radiator temperature as was set on them. THe radiators just get very hot - even at 8c!
I've removed and re-installed the stats a few times to be sure. When it's not installed you can fee it very loose/wobbly on the TRV. After holding down the button to installed hearing the spindle motor move the device becomes more firm on the TRV.
Anybody else having success with the Danfoss Living Connect? I've contacted Danfoss by email but yet to have a response.
I've also ordered another 9 thermostats so want to make sure they actually work asap!
6 answers to this question
