HC2 and Siren Fortrezz SSA
Guest jeromefr28
I just bought a HC2 and a siren Fortrezz SSA but HC2 (Fibaro Home Center 2) detects the siren like a dimmer light.
/emoticons/default_icon_sad.gif" alt=":-(" /> What should I do to run the siren with my HC2?
HC2 V1.033
5 answers to this question
Guest jeromefr28
    /emoticons/default_icon_exclaim.gif" alt=":!:" />
    Can you answer me?
    If this zwave siren is not compatible, I must return to the seller.
    Which zwave modules are validated on the HC2 ?
    i have the same problem. It's working but not full operated. From the status bar when you choose 1st bar it will be strobo light, when you choose 2nd,3rd,4th it will be siren. But there are nothing to configure in advanced option and also i cannot change "what is operating" to siren alarm.
    Guest jeromefr28
    I am disappointed in the lack of response and reactive support. it's been 3 days since I contacted technical support by the forum and email and still no response.
    Hi jeromefr28,
    Sorry for long answer for You questions - first of all this device is recognize as a dimmer in our home center 2, because it sending its state as dimmer - we do not have a template for this device.
    Can You tell me is it battery powered siren?
    Guest jeromefr28
    I use it with an electric power supply. I just understand.
    Using change of light, it works.
    0 = off
    1-33 = strobe lights active
    34-66 = siren only active
    67-99 = strobe lights and sriene active
    The SSA1 and SSA2 is therefore compatible with the HC2.
    thank you to piotr.janiak
