How can I reset module IDs with HC2?
Guest Eric
I would like to reset the IDs of my connected modules because it's getting more and more chaotic...by the way, my module IDs and node IDs are not equal anymore...does this lead to any problems?
I was able to reset the node IDs by resetting the Z-Wave network but was not able to reset the module IDs so....
.....how to reset the module IDs?
Fibaro HC2 1.033
In my opinion this isn't possible.
Guest jeromefr28
    Have you tried to contact Fibaro by email on [email protected] ? they communicate very little on this forum.
    /emoticons/default_icon_mad.gif" alt=":-x" />
    Guest Eric
    I wish Fibaro would communicate a little more in this forum indeed....
    However, problem is solved now, thanks to the help of ezHome.nl!
    The only way to reset the module IDs is to reset HC2 to factory settings with the configuration panel - NOT recovery mode!
    After reset, module IDs starting from number 1!
