2012 : Features request in the scenes
Guest jeromefr28
in the HC2 next release, can you add these features in the scenes ?
/emoticons/default_icon_idea.gif" alt=":idea:" />
in the module status : Dead Node Status and low battery status
use example :
putting a module in the car (the universal sensor) when the car leaves the house, the module is no longer reachable and status switches to "dead node". The HC2 disarm so all modules. When the car returned, the module is up , and HC2 disarmed modules.
other example :
if all module are in status "dead node", this means that there may be a power outage, the HC2 must send a notification.
in the action : custom Notification > Push / Email / SMS / Event log
with the custom field : email address, message and use of variables (date time, module name, module status)
Rename "Commands" by "Conditions"
in the commands/conditions : add the condition else
if .... then .... else ...
in the timer command "interval based" : add every x second
thanks
Fibaro Home Center 2 (HC2) V1.033
Guest jeromefr28
    Fibaro, can you give your opinion on this request ?
    When can we have the script LUA and API in HC2 ?
    For now, with the V1.033, the HC2 is too closed in comparison to the vera. (no API, no APP store, forum inactive...)
    jeromefr28,
    Thank You for all Your remarks - we will release new API probably tomorrow, You will have full LUA support there
    /emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" /> Also full documentation to new functionalities will be provided as fast as possibile!
    • 5 weeks later...
    totally agree with jreomefr28, thoses functionnality would be greatfull !
    especially adding mail notification into scene feature.
    • 3 weeks later...
    Guest SHCaus
    This NEEDS to be implemented, it's now 1.037 and there's still no notifications option in scenes?
    Also, the ELSE command would be perfect for feedback.
    I really hope this is added as soon as possible.
    SHCaus, as I said in other post:
    Fibaro has this functionality already. We didn't add it to 1.037 because it is old API and all new functionalities will be added to the new one. If you want to use such functionality to create notification from scene, just add there another Relay Switch module (it can be virtual switch from 1x3kW Relay Switch) and create scene. Firstly add notification to that switch about changeing its state and then create scene: IF Something THEN TurnOn Virtual Switch. Every time you will turn on that swtich system will send the notification - you can use it in any scene algorithm and it will work the same as scene notification.
    Guest SHCaus
    But the ELSE functionality doesn't exist?
    As long as the notifications feature is coming to scenes soon then that's okay, but currently it's not a viable solution for customers to do the virtual device work around.
    • 2 months later...
    Guest jeromefr28
    Fibaro, can you tell us the status of this request?
    Is coming soon
    /emoticons/default_icon_rolleyes.gif" alt=":roll:" /> If the next V2 exist, Fibaro must make it available quickly
    /emoticons/default_icon_evil.gif" alt=":evil:" />
    • 1 month later...
    Guest jeromefr28
    not this year...
    /emoticons/default_icon_mad.gif" alt=":-x" />
    • 1 month later...
    Guest jeromefr28
    [shadow=red]+2 months...[/shadow]
    Guest calvin4000
    Manque total de réactivité, à voir...
    • 11 months later...
    I see this old post and from my point of vew still interesting. Has this feature been implemented during 2013?
    dancar, I dont know how will HC2 Send notifications if there is a power outage like you described.
    I'll overcome this problem connecting an Ups and a 3g backup usb dongle.
    dancar, But if you connect UPS there wont be any dead nodes anyway right? So what will be there to report?
    Instead this phenomenon can work in a different scenario where I have actually used this with a different set of wiring dedicated to evacuation in terms of earthquake or fire.
    I'm supposed to UPS the HC2 and my l3 switch where the usb dongle 3g is attached and not all nodes in my house.
