Camera TP-LINK
Guest thales almeida
Hi, someone knows how to make the ip camera TP-LINK TL-SC3171G work on the system? I can't found the jpg path, and the MJPG stream path either. ThankYou
5 answers to this question
Guest jeromefr28
    hi,
    rtsp://ip_adx/video.mp4
    rtsp://ip_adx/video.3gp
    Guest GrZeCh
    check chapter 5 - 5.1.1 - Snapshot.
    oh, thank you. I found the jpg path and the mjpg stream path in another manual, and made the camera works. The url are:
    jpg path: jpg/image
    mjpg stream path: video.mjpg
    hi all,
    can fibaro accept RTSP:// url or just Http?
    i want to replace my DVR and want to make sure its going to work.
    the new DVR will support:
    rtsp://@////av_stream
    is that something acceptable with Fibaro ? or http:// the only way can integrate with Cam;s?
    thaks
    quote hyaman,
    would be useful to know whether Fibaro can accetp RTSP://
    I'm going to buy the Foscal C1 camera that doesn't support detach video via CGI due to hardware limitation of it's chipset.
    hi all,
    rtsp://@///
    /av_stream
    thaks
