2.137 beta is out
Guest jeromefr28
Most important Beta software features:
- Completely new system architecture, in which various devices types are treated as plugins. In nearest future this will allow for user created plugins.
- New, quicker and future oriented system architecture,
- Faster communication within Z-Wave network,
- Added support for Lua scripts,
- Automatic conversion from graphic block scenes to Lua scripts,
- Quicker scenes execution,
- Added possibility for Lua debugging,
- Full integration with Helios IP Home Entry System,
- Added VoIP functionality,
- New VoIP Panel added, for configuration and management of VoIP devices,
- Improved, much quicker sending commands to devices via the iPhone application.
Guest jeromefr28
    with 2.0137 beta :
    - my EZmotion 3 in 1 is KO
    - my Fortrezz SSA is not recognized as a dimmer light , so I can't use the strobe lights
    /emoticons/default_icon_sad.gif" alt=":-(" /> (
    - more events in the events panel since the update
    - the internet access by
    doesn't work
    I downgraded in 1.034, but the problems are still present
    I restarted 2 times.
    Can you help me ?
    Dear jeromefr28,
    We're checking Your issues - please remember it a beta functionality.
    Dear jeromefr28,
    He said "I downgraded in 1.034, but the problems are still present " so it's not a beta problem?
    Guest jeromefr28
    I don't know. I did the 2 updates in a row (1.033->1.034->2.0137 beta).
    Someone he encountered the same problem?
    I wait a reply from Fibaro.
    with 2.0137 beta :
    doesn't work
    Can you help me ?
    I've updated but access to home.fibaro.com works perfectly.
    (perhaps rebooting the router could help)
    Guest vayher
    was updated last night and works with beta version now.
    Guest thales almeida
    I made the update, and now, i have a problem to create de scenes using graphic blocks. I do the configurations, but after, i can't save it. What should i do?
    HI. is this new interface multi language, French?English? like version 1.033.
    Thanks for reponse.
    Thanks for reponse.
    Yes it is, it's even in Dutch
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />
    Guest jeromefr28
    So here are my result tests :
    - with the recovery mode I have refound the v1.034 and all is working again (EZmotion and Fortrezz SSA ok)
    - with the upgrade V2.0137beta, the EZmotion does not work any more (no more recognized) and Fortrezz SSA is not recognized as a dimmer light
    For the moment I keep V1.034
    Please let me know when issue is identified and solved.
    Thanks in advance
    Guest vayher
    There's a little bug with system rights to convert blocks to Lua in this version. Sorry for that. It's already fixed, being tested and will be released in tomorrow's update.
    Guest domoticawireles
    Hello, I'm using 2.137 beta firmware.
    Here the bugs I found
    - EZMotion not working
    - Loose of communication with Everspring SE812 Siren, Eversprig SF812 Smoke sensor, Everspring ST814 Temperature/Humidity sensor, HRT4-ZW Horstmann Thermostat (they are installed by max 3 mt from HC2) Do you think delete->add procedure will work?
    - Modify of device's "Polling time interval" is not saved by system
    - When I click on "Run" on a (not active) scene, the scene runs many times
    - You have to adjust many traductions to non-english languages
    How to use Voip functionality? We need some type of products?
    When energy measure of electricity? I see, on devices, you deleted field where I can write energy consumption in watts.
    The systems seems to work faster than before, and new features are impressive! Great work!
    Bye
    Guest Kuuno
    strongly recommend this update for advanced users only! If you have time to play around and maybe do a restore the try it but otherwise wait for the final release!
    Tested it out and the changes are great! LUA scripting needs some practise:)
    one bug i found was that executing bigger scenes did not work anymore
    i have a scene to check some variables and then lower projector screen but the screen started going up-down -some kind of loop. LUA event log showed error: something about scene already executed
