fb 0
Hello all,
I have a small zwave system based on the vera lite home center. The following devices are present on the zwave network:
5x FGS221
2x FGD211
1x everspring flood sensor
1x everspring door contact
All FGS221 devices are working correct after installation. They send status changes directly to the home center and to associated devices. After a while, the devices stops sending status changes to the home center and to associated devices. There seems a relation with the amount of switches made before the modules stops sending status changes.
I tried to re-join the devices to the zwave network. They start working again for a while before stopping again. The only other option seems to switch off and on mains supply, then the modules start working again for a while.
I tried as much I could think of, but the devices just stops sending status changes after a while. This is not how it is supposed to be!
Polling the devices still work, but is just not good enough. Polling time can take up to several 10's of seconds, which is really inconvenient! Local switching also keeps working.
It seems there is some firmware issue withe the FGS221 devices. I really would like some solutions before buying other devices. One solution would be some sort of soft reset of the modules over the z-wave network. In that case the soft-reset could be performed by the home center every night or so. Tips are welcome!
Frank
