2.138 is out
Guest jeromefr28
- Bug fixes and changes in scenes
- Bug fixes in virtual devices
- Bug fixes in devices icons
- Other bug fixes
Guest jeromefr28
    with 2.138 : EZmotion and siren are ok ?
    Hey Guys,
    In 2.138 you can't enter the W's anymore, and the W filled in in the "old" versions are gone and not shown anymore
    Furthermore, history report of the events doesn't work anymore.
    greetz,
    Mil
    Guest deraaij
    Hi all,
    I just migrated from Vera to HC2 running beta version 2.138. Can someone tell me if they have trouble with the FGD211 dimmer?
    When I switch or dim a lamp using the "real" switch the status isn't updated in HC2. Is that a beta issue?
    Correction: It looks if no device is updating in HC2 unless I use HC2 to switch a state...
    Mark
    I can confirm that I do not have this issue with 2.138
    All device states and adjustments are recognised across all interfaces (Desktop computer, iPhone application on both iPad and iPhone and configuration panel running on iPad)
    Tested Dimmers, Relays, Roller Shutter and Universal sensor connected to PIR
    Guest deraaij
    Thanks for your reply! Just to be clear everything works except when I switch an device on the device itself.
    Did you include any of those devices after the upgrade?
    I will restore and check if it works with a non beta version.
    Mark
    I tested all devices at the switch they are connected to and using the range of interfaces.
    All my devices were connected before I did the upgrade except a 2x1.5kW Relay. This is working fine also
    Guest deraaij
    Thanks for your rapid reply!
    Strange why it is not working for me.....
    Does anyone know whether this build (2.0138) fixes the issues with the EZMotion 3-in-1 sensor from 2.0137?
    Guest deraaij
    All,
    After a z-wave reset via the config panel and adding the devices once more all seems to work fine.
    Mark
    Guest deraaij
    Hi JohnnyC,
    Are notifications (push or e-mail for example) working for you in beta version 2.138?
    Thanks in advance!
    Mark
    I have reverted back to 1.035 due to stability issues while testing but will re update to beta in the morning and see what notifications are working.
    The beta is probably mostly for LUA script testing so there are quite a few things not working correctly (history panel, GPS localization etc). As my setup is mostly for display purposes I will be setting up a separate HC2 for beta testing tomorrow.
    Guest deraaij
    Thanks!
    Just started using my new HC2 device with beta 2.0138 installed.
    For now, I found the following issues:
    1. Device polling does not seem to work:
    - Under Configuration -> General, the "Devices polling time interval" changes back to 1343204844 every time I change it to a lower value (sometimes it seems to have changed just after saving, but it will change back sooner or later).
    - When changing the "Polling time interval" value on a device itself, the field gets empty again after saving the changes, so they never take into effect.
    As a result, switches that do not actively send their status to the HC2 after switching the device locally, the status in HC2 will never get up-to-date.
    Anyone else experiencing this issue? Or is there maybe a workaround available?
    2. The Event Panel does not show any event logs.
    Furthermore, a nice product with a good looking interface.
    Regards
    BAS
