Doorsensor tamper switches and Fibaro dimmers.
Guest vipernor
Hi I have some Fibaro FGD 211 Dimmer issues i can't figure out. When releasing the tamper switches on my Aeon Labs ADWS window/door sensor. It somehow sends alarm frames when they are moved and the fibaro dimmers starts going on and off. This is an awesome feature.
My question is simple. How do I turn that * off?
In the advanced configuration for the dimmer, change the parameter to "Device does not respond to alarms" Its one of the last parameters on the advanced configuration page
Parameter 30 for Dimmers
Any type alarm changes device state. Default setting: alarm changes device state to opposite, i.e. from ON to OFF Default Value Device cyclicly changes it's state after alarm is detected
Guest vipernor
    Thank you JohnnyC for the quick responds!
