2.141 beta is out
Guest jeromefr28
- Fixed critical z-wave bug (wrong device identification)
Everspring sensor no work.
fibaro switch malfunctions, the second module does not respond
I restored the hc2 twice and still the same, not fallen nodes removed correctly either.
Someone same thing happens?
Guest jeromefr28
    Have you tried using the "recovery mode" to delete old beta versions?
    To access RECOVERY MODE disconnect plug from power socket and hold Recovery button while plugging it back.
    this is the solution that I used to solve the problems of beta versions.
    I've had to re-register the modules
    Could you repeat the update 1.035 to 2.141 beta ?
    thanks
    thanks
    Thank you very much for the reply.
    After several attempts I decided not to install the beta version, it is true that I did from the recovey mode maybe that is the problem.
    when leaving the official version I'll try again.
    Thanks.
    beta 2.141 working fine for me. At first had trouble to add 3-1ezmotion sensor but after some deleting-adding it found it correctly and no problems since then.
    Guest Futuretech
    where can I obtain the beta?
    Guest ericf
    also me I would like to be able to have the feature to download the beta and install it
    Go to
    and you should see an option to try the beta IIRC. Since installing the beta i no longer see an option there.
    Guest ericf
    thanks for the answer but I don't see it anymore the option to allow the installation of beta version
    FIBARO told me that they have supsend this feature.
    Eric
