FGR221 no dimmer with mono-stable
Guest ninux
Hello
I have a Vera Lite under UI5 and I have 2 Fibaro FGR221 with 2 double mono-stable swith.
When I push S1 my roller only down 30 cm.
It's only work if I put 1 to paramter 10.
I try to exclude and include many time the FGR221 but always the same.
I try to reset with method 2 with out succes.
How can I return under learning mode to configure my roller shutter up and down ?
Thank you
Hi ninux,
If its work only with this parameter modificated please set this value to 1.
This is positioning OFF parameter.
I am afraid that Your problem is caused by the electronic limit switches in Your roller blind motor which our module are not compatibile with.
Guest ninux
    Hi Krystian
    Thank you for your answer.
    Could you confirm me if I exclude and include the FGR221 he should return on learn mode ?
    My roller shutter should be up ou down for the learn mode ?
    Regards
    What do you mean?
    It does not matter
    Guest ninux
    What do you mean?
    I would like to know if exclude and include put the device on learn mode to set up and down of my roller shutter like the first time when we do 2 full open and close ?
