Storage Options IP Camera Installation
Guest SunPower
Guest SunPower
I have a Storage Options IP Indoor Camera, which I want to connect to my recently bought HC2. Does somebody tried same, and what are the settings for the Camera device setting? I don't see the Storage Option camera in the device list. Many thanks for help! Cheers
These should be in the manual for the camera itself. If not you will need to request these from the manufacturer. They should have video and snapshot paths and also PTZ decoder values for the movement if available
Guest SunPower
  • I finally got it to work. Still I haven't got the codes to make it move. In meantime discovered that the camera is same as a Netwave IP Camera.
    Seems HC2 is offering more a puzzle environment than I expected.
    Anyhow a little progress in the set-up.
