Everspring Fire Alarm Units, how to make it work
Guest SunPower
Guest SunPower
I have three Everspring Fire Alarm units, and I'm quite new to HC2 system. I would be pleased if someone can show me:
1. How to arrange the fire alarm settings, so that when one goes of the other two would follow with alarms as well?
2. How if a fire alarm goes off, then how does it trigger the Alarm unit to make noise and light as well?
3. How it would trigger the sending of a SMS
You will need to test this with the 3 devices but there is an "Associations" option under the advanced tab for Everspring Smoke Alarms. If you select "Set Up" and choose the other 2 alarms form the list they may see each other and respond. Try it out and see if the other alarms respond when you press the test switch on the smoke alarm.
If this doesn't work you could create a scene for each device so that if one goes of the others respond
I'm not sure I completely understand but I think you mean that when the smoke alarm goes off, the house alarm responds? You would have to create a scene that would trigger the "Breach" relay on your alarm panel.
You need to setup a notification (Panels > Notification Panel) specific to this alert. Then select this notification under "Notify me" in the advanced tab of the device for the function you wish to be notified of. This can also be by push or email or all 3
