how to upgrade to the beta version ?
Guest imparator
hi, the first time i start my home center, i see a upgrade to beta, now i cant see this,
i am running 1.035 now , but i want to upgrade to the latest beta
can some one tell me how i can do this ?
dns is set to 8.8.8.8
5 answers to this question
Guest Futuretech
    we can force this update to Your HC2 manually. If You have Your hc2 on public IP send me this on: [email protected]
    How do i set it to public IP?
    Futuretech,
    First of all you must have public IP domain, than you need only to insert this public IP data in Home Center 2 configuration settings. Then Your HC2 will be available from internet by it's own Public IP address.
    Guest GrZeCh
    I would be not so sure about setting public IP in HC2 configuration. If you have not connected your modem directly to HC2 (and by looking at your screenshot I'm sure your HC2 is not connected directly to some kind of cable modem) then don't change your HC2 IP address. A lot of people use routers with modems to connect to the internet so you will have probably create TCP port (ports: 22 and 80) redirection from your router admin panel (192.168.0.1) and set it to your internal LAN HC2 IP address (192.168.0.69). Check your router manual for that. If you don't know how to do that then you will have probably wait for normal beta release.
    Guest Cirion
    I have sendt an email to [email protected] with my info, please force my update tp latest beta.
