Android IP Webcam support
nmnetmedia
Hello
I'm trying to setup a android phone as IP camera.
The application/software can stream jpeg and is compatible with most IPCam software applications, however I'm not able to configure it with Fibaro:
Here is the Jpeg/videofeed path:
/videofeed'>
/videofeed
Application IP/Cam info:
Is there anyone who can help me with this please?
Thank you,
Nico
4 answers to this question
In advanced configuration under "New Camera"...
In "IP address" put: "nmnetmedia.dyndns.org:8080" (without quotation marks)
In "MJPEG Stream Path" put: "videofeed" (without quotation marks)
You might want to access the cameras software and add password though because I am looking into your back yard right now. Once you have created the username and password in the camera software you will need to add these details in the camera configuration on the HC2
  • In advanced configuration under "New Camera"...
    Great! thanks for this fast reply!
    Everything works now.
    I was using the wrong path.
    Have a nice day & keep up the good work!
    Guest thales almeida
    Hi, can you explain what do yo did to configure the android camera? I'm trying to do this too, but don't know how. Thanks
  • Hi,
    Here's the app I'm using:
    Works like a charm! You just need to enter the IP, port and right path to the stream (videofeed)
