controlling scenes with universal sensor
Guest Kuuno
how do you assign scene to specific button input type?
i tried creating a scene where: button 1 == ON then run scene with no luck
anyone tested this?
thanks!
  • 3 weeks later...
Guest markhellier
    I have scenes triggered by both motion and temp change in universal sensor.
    If button1 == "breached" then action. This is how I test motion sensor.
    I've attached a scene, which is triggered by motion.
    I also test for nighttime and make sure the light is off.
    Guest Kuuno
    yes this is simple but have you tried to trigger a scene by pressing a button. eg pressing the button twice triggers the same scene you have in the sample
    thanks!
