Chris 0
Hello Fibaro Team, Forum,
As a new user, I installed the HC2 since yesterday.
Untill now, despite the lack of a manual (which is really needed, step by step), I seems to get it right.
Only issue so far I have is the remote acces.
What I have done so far:
Installed HC2
Update firmware to 1.036
Lan settings: static IP
DNS: the actual one (so my gateway/routers IP adress). I've read that default the google's 8.8.8.8 is allready programmed as second DNS in the HC2 system. Correct?
remote acces allowed on HC2: Yes
I created an account on the home.fibaro.com website
Downloaded to app from appstore (today)
I added the settings for local acces ( local IP adres of HC2, login admin/admin etc.) and my username from the home.fibaro.com to the remote settings line. I left the pasword blank
Now:
Locally everything works ok via iphone.
When I login via the home.fibaro.com the remote acces works ok.
I see my HC2 serial number and can open it.
Remote acces via the iphone (outside the LAN) via 3G (good connection) sometimes work, but most of the time doesn't work.
I type my pasword, the serial number of the HC2 appears.
When I click on the icons nothing happens. Also weather etc. don't appear.
I tried refresh network a dozen of times, log off/on dozen of times.
Only sometimes it works.
What is wrong here?
Thx,
Chris
8 answers to this question
