Has anyone tested these devices with HC2?
Guest domoticawireles
Dear Forum users and Fibaro engineers,
has anyone tested these devides with HC2? They are working properly?
- Aeon Labs KEY FOB (with 1 or 4 buttons)
- Aeon Labs MULTI SENSOR 4 in 1
- Everspring DOOR BELL UTSE03A
- Aeon Labs energy clamp
- Poly Control POLY PAD
- Any wireless wall button battery powered to run scenes?
These products are very interesting!!!
Thank you very much.
Guest LaMax
    I have only the Aeon Labs energy clamp. this device works only on beta firmware, otherwise it isn't recognized.
    I have the minimote instead the Key fob but it doesn't work
    Door bell utse03a also not recognized in firmware 1.036.
    Hi the fibaro's team.
    Do you plan to support this products from Everspring and Aeon labs ?
    Most of these devices will be supported by the Home Center 2, but making it compatibile takes some time. Currently we are testing tens of new Z-WAVE devices.
    Guest deraaij
    I bought the Aeon Labs MULTI SENSOR 4 in 1 but for now only the motion sensor works
    Is there a time line for when this device will be included? I was mainly interested in on of the other 3 sensors
    Mark
    I got an Aeon Labs Wall Plug Switch model DSC06106 with metering. It is recognised as an On/OFF swith, but I got no metering features. Am I wrong? Are you planning adding this feature soon?
    Best Regards.
    Jose
    Guest SHCaus
    Best Regards.
    Jose
    I'm pretty sure this feature is only in the beta software, so it should be available soon.
