Hey,
I have bought the UNIVERSAL BINARY SENSOR and woundering what kind of power supply i can use for it. I tried to connect a mobile phone charger that deliver 12V and 1Amp, but the small circuit got really hot and burned a hole in my carpet when i tested it. The i connected a small 12V batteri to it = it worked fine and didn´t get all that hot. But i dont what to use batterysupply, i want permanet power.
So my question is, what kind of power supply can i use? Do you have a weblink to a product that you could recomend?
Guest jeromefr28
Supply voltage : 9-30V DC ±10%
Be careful not AC power supply
+ on red conductor
- on blue GND conductor
if you reverse the polarity, it will heat and smoke!
/emoticons/default_icon_exclaim.gif" alt=":!:" />
    The mobile charger delivers 12V DC 1Amp. When i reversed the polarity nothing happend, i didnt get hot, no smoke.
    Guest jeromefr28
    have you checked the polarity and voltage with a multimeter ?
    if he smoked the module may be dead
    No i havent, waiting for the multimeter to arrive (bought one from dealextreme).
    Guest Loop
    I have a similar problem with my binary sensor and my multimeter shows 11.6V DC, but the sensor is still not working. I use a bell-transformator (12VAC) and a bridge rectifier to get the 12VDC for my power supply.
    If i use a mobile phone charger then the sensor works. In this case my multimeter shows 16VDC.
