Setup Lili & voice commands
I'm trying to configure a voice command using my Iphone.
Are there any info documents available ?
Can someone show me an example what I need to fill in in the following fields:
Lili turn on command:
Lili turn off command:
Sample:
Thank you,
Nico
19 answers to this question
Hi, I'm not an expert (yet!), but I typed in "dining room lights on" and "dining room lights off", then went to my iphone and invoked LiLi, spoke those words, and to my surprise the very pleasant female automated voice spoke back to me, and, switched the lights on and off!
Impressive...
    Awsome
    /emoticons/default_icon_smile.gif" alt=":-)" /> This works!
    Thanks for the tip!
    I'm just waiting to meet LiLi now.. I'm hooked on her voice..
    Guest Dennis
    BUG ?
    When I (in vers. 1.036) add any command in the LILI line then the explorer crashes and will not save the command ? ?
    iam using explorer, Opera and Firefox and all three will hang when i click on save after putting al tekst line in the command
    BUG ?
    I have exaclty the same issue.
    Firmeware 1.036.
    Can't add any lili command to my HC2.
    I'm also running 1.036 using Firefox 14.01
    Not having any problems, browser not crashing here, works great!
    Impressive!
    MMmmmm... really strange, i'm also using firefox 14.0.1...
    trying with 2 computers using windows 7 32 bits -> crash.
    trying from a ipad with Safari -> crash.
    tryong from a iphone with Safari -> crash.
    nmnetmedia from witch kind of OS/config are you working with ?
    trying to find the differences ...
    /emoticons/default_icon_question.gif" alt=":?:" />
    Guest Dennis
    Same problem here! Strange Bug
    I'm using Windows 7 (64Bit)
    Just installed Chrome 21.0.1180.79 m and can confirm that it's working too.
    I recently needed to disable/uninstall my skype browser plugin for another application.
    Maybe you could give that a try ?
    Good luck!
    Guest Dennis
    Good luck!
    No read the post above. Even whit a ipad it will not work. So it must be a Bug in Fybaro self.
    (even the ipad crashed ??
    /emoticons/default_tongue.png" alt=":P" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />)
    it's not really the Ipad who crashed, in fact, it's the ipad's safari session who is crashing, so you won't be able to acces to the HC2 since you totally kill safari's process (kill form the mutlitask bar).
    After that, you can reload safari and acces to your HC2.
    it's happen 100% of the time when i save a lili command to a module. (it's on a fibaro dimmer module).
    From my samsung 10.1 galaxy tab I'm not able to save any config settings, it's not crashing and I'm not getting any errors either. Computer works fine, just tried from another system XP 32bits and works too.
    Maybe one last thing, still using default user admin/admin on my testbox
    Good luck
    Nico
    i tryed creating a new admin user with creditential : admin/admin.
    login with this account.
    add a lili command in the dimmer device -> session crash.
    the same issue.
    really don't know what to do next... Maybe should wait for a feedback of the fibaro's team ?
    it seems to be a bug of the HC2, but i can't find the exactly circumstances.
    I did some tests from different computers and did not have any problems so it's probably not browser/computer related.
    It might be something caused by up/downgrade.
    Last week I did some tests with 1.140 and 1.141 beta so it might have changed something on my box. currently running 1.036 again.
    Did you restore to 1.036 after putting the device through the recovery process or did you just restore to a backup?
    If you did not enter recovery mode first, the HC2 will still be trying to operate on 2.141 structure with 1.036 settings which are completely different.
    Hi again, I did not entered recovery mode, so it's probably still running on the newer structure. Good news anyway that we found "why", and it's working fine
    so keep up the good work guys!
    i have the same problem but i had never update my HC2 to beta firmeware.
    I've bought it one month ago with FW 1.027 out of the box -> update to 1.034 and to 1.036.
    nothing else.
    and still have the bug with lili command.
    Guest Dennis
    nothing else.
    same here
    Firmeware 1.036.
    Thank you for your concerns
    We are checking this issue currently.
    I will ensure to make it work fine in next 1.037 version.
