Virtual module : Make an GET HTTP request to a domaine.
Hi all,
i would like to avec a "send mail to" function for my scene.
HC2 in 1.0.36 do not have it yet.
So, why not using a virtual module to connect to an HTTP mail API to send the mail ?
Well, i tryed to setup a virtual module to connect to "http://www.pushingbox.com" services (a very usefull push service, including mail).
it's very easy, just have to send a GET request to "api.pushingbox.com/pushingbox" with a "devid=xxxxxxxxxxxxxx" command to use the pushingbox profil you want.
But it seems that you can not use the virutal device with a domaine name... (see screenshot)
i tryed to make it work with pushingbox direct ip adresse, but the service is unavalable this way.
To Fibrao's team, will you open the virtual device to domaine name resolution ?
it's could be ussefull to connect the HC2 to external services.
6 answers to this question
Guest jeromefr28
/emoticons/default_icon_exclaim.gif" alt=":!:" />
this will bypass the lack of scripts
Guest FibaroKK
+1 !!
Agree
Absolutely agree!
+1 for this functionality from me also!
It looks like the HC2 is just setting a max length of the string that can be set in the "IP Address" field....
Guest jeromefr28
in the V1.037 please
jeromefr28, you will http communication it in 1.037 or 1.038
/emoticons/default_icon_cool.gif" alt="8-)" />
    sounds very good !
    thanks Krystian !
