Guest WEHA
So I have paired the HC2 with a HRT4-ZW (thermostat), so far so good.
In the zwave manual of the thermostat (
) art 3.2.5 it says that you can retrieve the measured temperature.As stated in this post (
) full support would have been made somewhere in April.So I'm wondering how I can see the temperature measured by this device and if it is making a call for heating.
The only thing I can do now is set the activation temperature on the Fibaro/Thermostat (they sync fine).
I've tried with scenes where if thermostat is ON set var 1 or whatever, no luck.
History panel only reveals set temperature (no heat call or temp sensor)
your help is appreciated.
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />FYI: I just got my HC2 2 days ago so bare with me
/emoticons/default_smile.png" alt=":)" srcset="https://forum.fibaro.com/uploads/emoticons/[email protected] 2x" width="20" height="20" />regards
UPDATE:
So apparently history DOES give the temp sensor but under the same name
So line 81 to 85 is the temperature sensor (i put it in a cooler room) and 80 is me setting the thermostat to 20.
The device page on the HC2 does still say 20 however.
