Device configuration 1.036
If you change the configuration of a device under the advanced option, and save it, what should happen? My HC2 seems to freeze and when I go back to the configuration there is nothing listed. Secondly, If I go to the event panel to see if I can see the change, I have blank boxes where the time/date should be. Are these 2 things normal?
Chris
Guest zebox
Blank boxes in event panel seen at work via MS IE.
    You are correct- the blank boxes are related to the Microsoft Internet Explorer- Thank you!
    I can see the Event Panel with my Android Tablet: Should a configuration change come up under Event Panel?
    Now I have 1.037, the device configuration shows for the roller shutter module, but not for the dimmer module. Do other users have the same problem? Your replies would be appreciated.
