Dear,
I've just plugged my new Fibaro HC2 with 11 Fibaro devices (dimmer, switches and roller shutter).
After installing the wire step of Roller Shutter I've included it into zwave network without problems. But I'm not able to calibrate the rollers correctly. I did an up&down 2 times, but after that when I try to put into an specific opening the roller is not in the right place.
I've read the the Shutter manual, and HC2 info but I can´t find a detailed step by step guide about how to do that.
Could anyone please help me?
Thanks a lot.
Guest FibaroKK
Try to remove roller shutter from HC2 and add it again and recalibrate
    I did it ... I've removed it.
    Then include it pushing 3 times the key.. then up and down twice..
    Is there any other option within HC2 interface advanced options?
    Yo no he tenido problemas con el ajuste, simplemente bajar las persianas y luego subirlas y sin problemas, eso sí, las persianas ya venían ajustadas de fabrica, que puede ser ese tu problema.
    Un Saludo.
    I've had no problems with the fit, simply lower the blinds and then upload and smoothly, yes, the blinds were already factory fitted, it may be that your problem.
    A greeting.
    The top and down position were calibrated by their motors (for a manual use). What I'm talking about is that HC2 could be able to know when (how many time), it takes to be up or down, so, it could calculate the right position.
    My goal is to be able to put 30% in HC2 an get a 30% opening in the blinds. I couldn´t get it... Is there any way with advanced options or any new clue?
    Hi!,
    Do you have mechanical limit switches in your roller blinds? We are able to position only roller blinds with mechanical limit switches - if you have electronical, please modificate parameter 10 (for positioning off) - you will be able to control the roller blind, but not to position it.
    Right now I can use de slider to set a certain position and it almost works.. The position is higher or lower, but it´s now exactly to the % value... So what I try is to fit this value to the right position.
    • 8 months later...
    Please advise on whether you were able to find a solution using it with electronic limit motors.
    If you calibrated the Fibaro Roller Shutter module, will it work ??
