Logitech Squeezebox Radio
piotr.janiak
try setting (server.plugins) - Plugin Module Loading to debug in advanced debug and see if the logs show anything
[ Added: 2013-09-29, 15:47 ]
Any luck?
[ Added: 2013-09-29, 22:49 ]
also
permissions
[ Added: 2013-09-29, 23:04 ]
[ Added: 2013-10-06, 23:41 ]
Any luck?
also
permissions
also if you are running old perl modules try update
cpan or manual
I found a usefull command for squeezebox that is not very documented, the ability to use preset buttons
button playPreset_x (x can be equal to 1 to 6)
  • Somebody know why i cannot send any command? I'll try but nothing happends...
  • Ok, i was reinstall LMS and now it's working.
    I power the simplest command like play, mute etc.
    How to play file which is added to /fibaro/1.mp3 ?
    try
    full list at /html/docs/help.html of your lms server
  • Thank you robmac, now everything works great and i have voice commands that something happends.
    try
    Hi all,
    How can I use google TTS on logitech Squeezebox to speak, similar to Sonos?
    I use a virtual device label to transfer the notification string from the scene to the virtual device that makes the call to the squeezebox. I then use code to press the button.
    so the original code from my virtual device button had this line with the spaces replaced
