I'm not amused
Guest SunPower
I must say that the 1.037 . I spend again halve a day trying to figure out the issues. I tried to add the new devices, which were recognised at first. However I can find the back in the devices overview. I'm deeply disappointed with this very poorly designed OS.
This description is a little vague... There must be a reason WHY these things are happening but if you want us to help you may need to go into a little more detail. Try answering the following:
At what point did the devices not appear in the overview?
What software version were you running when everything was fine?
What are the devices that are missing and what have you specified they control?
At a glance (looking through some of your other posts) you were running the beta version at some point. Did you completely revert to factory software (1.009) before restoring and upgrading to 1.037?
The beta is a completely different software architecture. So if you simply tried to restore to a backup the software will still be trying to run on the new architecture which will cause huge issues with devices.
The warning below was attached to EVERY beta version software update which I have had to remind people of on more than one occasion so this could be the cause of your issues also.
WARNING!
Upgrade to Beta software cannot be reversed by standard software upgrade procedure. The only way to come back to official software is to use Recovery Mode, then use backup and upgrade to official software version. It is highly recommended to create backup file before attempting to install Beta software.
After update to Beta software all devices will be automatically reconfigured to work with new system architecture. All devices settings and parameters will be saved. Reconfiguration progress will be shown in pop-up window.
Guest SunPower
    Yes, probably I did as you said. I will put it back on factory settings and then try again. Cheers
