My HC2 seems to be dead, all the lights on the front are on (see attached photo), and it does not go in to recovery mode when the button on the back is held down.
The unit does not respond to pings, and the HC2 Finder app cannot find it...
Any ideas?
if you remove the little plate at the back, you should be able to connect your monitor:
I would give that a try.
Good luck
