ventilation control
Guest Kuuno
Pls share your experience and various methods you have used to control ventilation.
Just turning the vent on-off is not good enough. how do you control various speeds of ventilation and so on...
thanks!
  • 1 year later...
Hello. Where is your reflexion on control ventilation home ?
I am as you, i search for construction scenario for VMC.
I control my ventilation using a RGBW module.
The motor of my central ventilation system has a 0-10V Control Input.
1.7, V corresponds to 50 m³/h, 10 V corresponds to 300 m³
I powered the RGBW module using a 12V DC adapter and connected:
0-10V Control Input + to IN1
0-10V Control Input - to R
I control my ventilation (storkair 550) with a raspberry pi (trough an RS232 connection)
on the raspberry there is a perl script who gives me a web inteface but also push settngs and a json
I the created a virtual module to control everything
running now for 3 months perfectly !
part of code:
I can now control my ventilation from my phone and also regarding the CO2 level.
Doesn't that present any problems? As I understand from the manual, the RGBW can't provide a real 0-10V output signal, only 12V PWM.
Could you share full code ? I have also storkair (zehnder) ventilation, raspPI and i would be greatful if i can manage this device from fibaro
  • 1 month later...
Leon - how is your ventilation working with pwm signal?
[ Added: 2014-05-29, 10:37 ]
I found good solution to use RGBW to control 0-10V input devices (ventilation etc)
WeI used two options so far in homes of our customers.
1, we've used a Fibaro dimmer to preset the ventilationlevel on a toilet ventilator, it works well for this client because in the past it makes too many noise and now its more silent. He turns it on and off with a motionsensor while the light turns on.
2. In Holland we have in all new build houses ventilation boxes with 2-1-3 switches connected to them. The box is always working on level 1 and you can switch 2&3 to speed it up. We use a Fibaro 2x1,5kW switch to switch level 2&3 . You can also associate with shower humidity or with kitchenlight, toiletlight, bathroom light etc.
smartronix,
Can you share the second option how you configured that? I have an Itho box, but I only have now on or off..
